Ana içeriğe geç
Palm Centro Speakers Replacement
Neye ihtiyacın var
  1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: adım 1, 2 resimden 1. Palm Centro Speakers Replacement, Disassembling Palm Centro Battery: adım 1, 2 resimden 2.
    • Press and slide open the battery cover.
  2. Palm Centro Speakers Replacement: adım 2, 1 resimden 1.
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Speakers Replacement: adım 3, 1 resimden 1.
    • Phone with battery removed
  4. Palm Centro Speakers Replacement, Back Housing: adım 4, 1 resimden 1.
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Speakers Replacement: adım 5, 1 resimden 1.
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Speakers Replacement: adım 6, 2 resimden 1. Palm Centro Speakers Replacement: adım 6, 2 resimden 2.
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Speakers Replacement: adım 7, 2 resimden 1. Palm Centro Speakers Replacement: adım 7, 2 resimden 2.
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Speakers Replacement: adım 8, 2 resimden 1. Palm Centro Speakers Replacement: adım 8, 2 resimden 2.
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Speakers Replacement: adım 9, 2 resimden 1. Palm Centro Speakers Replacement: adım 9, 2 resimden 2.
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Speakers Replacement, Logic Board: adım 10, 1 resimden 1.
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Speakers Replacement: adım 11, 1 resimden 1.
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Speakers Replacement: adım 12, 1 resimden 1.
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Speakers Replacement, Speakers: adım 13, 3 resimden 1. Palm Centro Speakers Replacement, Speakers: adım 13, 3 resimden 2. Palm Centro Speakers Replacement, Speakers: adım 13, 3 resimden 3.
    • Pry the four plastic latches free that connect the antenna to the logic board.
    • Excessive force may damage your logic board!
    • Remove the antenna from the logic board.
  14. Palm Centro Speakers Replacement: adım 14, 1 resimden 1.
    • The internal speaker is attached to the antenna. To remove it, pry the speaker from the antenna using the tip of your screwdriver.
    • The speaker should be placed back into its spot in the correct position. Take notice of the gold connectors
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin
31 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-49, Garner Spring 2010 Cal Poly, Team 15-49, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G49
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,498
