Giriş
By following these steps you can successfully repair your device.
Neye ihtiyacın var
Gently pull off plastic device cover where it connects to the rest of the Palm IIIc.
Bu adımda kullanılan alet:Tweezers$4.99
Use tweezers to pull up the ZIF connector (the brown plastic tab) on the back of the motherboard and disconnect the tail, which looks like a ribbon.
Once the ZIF connector is unattached, remove the clear screen cover using a spudger. Some force may be necessary.
Neredeyse bitti!
Sonuç
