Giriş
Follow this guide to replace a non-working screen with a new one.
Parçalar
Hiçbir parçaya gerek yok.
  1. Keep track of all pieces removed from the device.
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
    Yorum Ekle
  2. Using a Phillips head screw driver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • Using a Phillips head screw driver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
    Yorum Ekle
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
    Yorum Ekle
    • With the device on its back, you should now be able to see the motherboard; behind it you will find a plastic clamp, the tab of a ZIF connector, pop it out and remove electric ribbon cable.
    • The use of a prying tool is recommended.
    Yorum Ekle
    • Pop out the old screen and insert the new one.
    • The adhesive may create some difficulties, but the screen should come off without using much force.
    Yorum Ekle
Sonuç
Paulina Trujillo
241 İtibar
9 adet Kılavuz yazıldı
Takım
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S20G69
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 1,228
