Ana içeriğe geç
Palm IIIx Front Button Cluster Replacement
Neye ihtiyacın var
  1. Palm IIIx Front Button Cluster Replacement, Battery: adım 1, 1 resimden 1.
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: adım 2, 1 resimden 1.
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: adım 3, 1 resimden 1.
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: adım 5, 1 resimden 1.
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: adım 6, 1 resimden 1.
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: adım 7, 1 resimden 1.
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
Sonuç
David Haskell
44 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-43, Regan Winter 2010 Cal Poly, Team 14-43, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G43
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 1,353
