Ana içeriğe geç
Palm IIIx Motherboard Assembly Replacement
Neye ihtiyacın var
  1. Palm IIIx Motherboard Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Motherboard Assembly Replacement: adım 2, 1 resimden 1.
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Motherboard Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the old batteries one at a time.
  4. Palm IIIx Motherboard Assembly Replacement, Motherboard Assembly: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Motherboard Assembly Replacement: adım 5, 1 resimden 1.
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Motherboard Assembly Replacement: adım 6, 1 resimden 1.
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Motherboard Assembly Replacement: adım 7, 2 resimden 1. Palm IIIx Motherboard Assembly Replacement: adım 7, 2 resimden 2.
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Motherboard Assembly Replacement: adım 8, 1 resimden 1.
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Motherboard Assembly Replacement: adım 9, 1 resimden 1.
    • Separate the motherboard from the screen.
  10. Palm IIIx Motherboard Assembly Replacement: adım 10, 1 resimden 1.
    • Now the motherboard assembly can be replaced successfully.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ben Johnson
22 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-43, Regan Winter 2010 Cal Poly, Team 14-43, Regan Winter 2010 üyesi
CPSU-REGAN-W10S14G43
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 3,162
