Ana içeriğe geç
Palm P101UNA Charger Outlet Replacement
Neye ihtiyacın var
  1. Palm P101UNA Charger Outlet Replacement, Battery: adım 1, 1 resimden 1.
    • Push in the button at the bottom of the phone, and lift the back cap off.
  2. Palm P101UNA Charger Outlet Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling out the little tab.
  3. Palm P101UNA Charger Outlet Replacement, Charger Outlet: adım 3, 1 resimden 1.
    • Turn phone over on its left side and remove single phillip's head screw using the Phillips #0 screwdriver.
  4. Palm P101UNA Charger Outlet Replacement: adım 4, 1 resimden 1.
    • After screw is removed take the plastic opening tool and apply slight pressure to even out bends in the metal
  5. Palm P101UNA Charger Outlet Replacement: adım 5, 1 resimden 1.
    • Insert charger to check adjustments to metal outlet
Sonuç
ironwill13791
509 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 274
