Ana içeriğe geç
Palm P101UNA Speaker Replacement
Neye ihtiyacın var
  1. Palm P101UNA Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Push in the button at the bottom of the phone, and lift the back cap off.
  2. Palm P101UNA Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling out the little tab.
  3. Palm P101UNA Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Using the 1.5mm hex screwdriver, remove the 6 hex screws from the inner-most casing.
  4. Palm P101UNA Speaker Replacement: adım 4, 1 resimden 1.
    • Using the spudger, remove the inner case from the phone.
  5. Palm P101UNA Speaker Replacement: adım 5, 2 resimden 1. Palm P101UNA Speaker Replacement: adım 5, 2 resimden 2.
    • Unplug the wire from the speaker using the tweezers.
  6. Palm P101UNA Speaker Replacement: adım 6, 1 resimden 1.
    • Pry out the speaker from the back of the phone using tweezers.
    • Applying pressure from the back of the speaker may help.
Sonuç
ironwill13791
509 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 206
