Ana içeriğe geç
Palm Pilot Professional 3com Plastic Frame Replacement
Neye ihtiyacın var
  1. Palm Pilot Professional 3com Plastic Frame Replacement, Keypad: adım 1, 1 resimden 1.
    • Unscrew the three screws on the back of the Palm Pilot.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Pilot Professional 3com Plastic Frame Replacement: adım 2, 2 resimden 1. Palm Pilot Professional 3com Plastic Frame Replacement: adım 2, 2 resimden 2.
    • Pull the back cover from the bottom of the device and separate the interlocking tabs on the top to remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Pilot Professional 3com Plastic Frame Replacement: adım 3, 1 resimden 1.
    • The front plastic cover is now free to be removed from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Pilot Professional 3com Plastic Frame Replacement: adım 4, 1 resimden 1.
    • The keypad is now free to be removed from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  5. Palm Pilot Professional 3com Plastic Frame Replacement, LCD Screen: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Looking at the back of the device hold one of the white tabs on the ribbon cable connector down and use tweezers to push in the other white tab toward the device at the same time.
    FixBot'a Sor
    Yorum Ekle
  6. Palm Pilot Professional 3com Plastic Frame Replacement: adım 6, 1 resimden 1.
    • The ribbon cable is now loose. Use the tweezers to carefully slide the ribbon cable out of the connector.
    FixBot'a Sor
    Yorum Ekle
  7. Palm Pilot Professional 3com Plastic Frame Replacement: adım 7, 2 resimden 1. Palm Pilot Professional 3com Plastic Frame Replacement: adım 7, 2 resimden 2.
    • The screen is now disconnected from the rest of the device and can now be removed.
    FixBot'a Sor
    Yorum Ekle
  8. Palm Pilot Professional 3com Plastic Frame Replacement, Plastic Frame: adım 8, 2 resimden 1. Palm Pilot Professional 3com Plastic Frame Replacement, Plastic Frame: adım 8, 2 resimden 2.
    • Depress the tabs around the battery casing so that the battery casing can slide through the rectangular slot on the motherboard - opposite of the metal plate.
    FixBot'a Sor
    Yorum Ekle
  9. Palm Pilot Professional 3com Plastic Frame Replacement: adım 9, 2 resimden 1. Palm Pilot Professional 3com Plastic Frame Replacement: adım 9, 2 resimden 2.
    • Pull/push the battery casing through the rectangular opening. The mother board should now separate from the plastic frame.
    • Note: The frame might have to be wiggled towards the left (when the springs are facing left) to become fully released.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kevin Santos
1 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-4, Benson Spring 2012 Clemson, Team 2-4, Benson Spring 2012 üyesi
CLEM-BENSON-S12S2G4
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 46
Her zaman: 1,283
