Ana içeriğe geç
Palm Pre 2 Keyboard Replacement
Neye ihtiyacın var
    1. Palm Pre 2 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Palm Pre 2 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
      • Make sure your Palm Pre 2 is turned off before taking apart the phone.
      • Snap off the back panel to reveal the battery using the opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. Palm Pre 2 Keyboard Replacement: adım 2, 2 resimden 1. Palm Pre 2 Keyboard Replacement: adım 2, 2 resimden 2.
      • Pull on the tab to remove the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Palm Pre 2 Keyboard Replacement: adım 3, 2 resimden 1. Palm Pre 2 Keyboard Replacement: adım 3, 2 resimden 2.
      • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
      FixBot'a Sor
      Yorum Ekle
    4. Palm Pre 2 Keyboard Replacement: adım 4, 2 resimden 1. Palm Pre 2 Keyboard Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas.
      • Use tweezers to remove the two antennas from the keypad control board.
      FixBot'a Sor
      Yorum Ekle
    5. Palm Pre 2 Keyboard Replacement: adım 5, 2 resimden 1. Palm Pre 2 Keyboard Replacement: adım 5, 2 resimden 2.
      • Use the opening tool to pry off the (black and yellow) back frame.
      FixBot'a Sor
      Yorum Ekle
    6. Palm Pre 2 Keyboard Replacement: adım 6, 3 resimden 1. Palm Pre 2 Keyboard Replacement: adım 6, 3 resimden 2. Palm Pre 2 Keyboard Replacement: adım 6, 3 resimden 3.
      • Use the opening tool to remove the panel on the main part of the phone.
      • Use the tweezers to get access to remove the panel giving access to the cable connectors.
      • Remove the two ribbon cable connectors using the tweezers.
      FixBot'a Sor
      Yorum Ekle
    7. Palm Pre 2 Keyboard Replacement: adım 7, 1 resimden 1.
      • Use tweezers to separate the keyboard from the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Elliott Van Hoy
256 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Freund Spring 2018 IUPUI, Team S1-G6, Freund Spring 2018 üyesi
IUPUI-FREUND-S18S1G6
2 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 30
Her zaman: 492
