Ana içeriğe geç
Palm Pre 2 Motherboard Replacement
Neye ihtiyacın var
  1. Palm Pre 2 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Palm Pre 2 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Palm Pre 2 Motherboard Replacement: adım 2, 3 resimden 1. Palm Pre 2 Motherboard Replacement: adım 2, 3 resimden 2. Palm Pre 2 Motherboard Replacement: adım 2, 3 resimden 3.
    • Pull on the tab to remove the battery.
  3. Palm Pre 2 Motherboard Replacement: adım 3, 2 resimden 1. Palm Pre 2 Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
  4. Palm Pre 2 Motherboard Replacement: adım 4, 2 resimden 1. Palm Pre 2 Motherboard Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas (Reference the red box in the image).
    • Use tweezers to remove the two antennas from the keypad control board.
  5. Palm Pre 2 Motherboard Replacement: adım 5, 2 resimden 1. Palm Pre 2 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the opening tool to pry off the (black and yellow) back frame.
  6. Palm Pre 2 Motherboard Replacement: adım 6, 3 resimden 1. Palm Pre 2 Motherboard Replacement: adım 6, 3 resimden 2. Palm Pre 2 Motherboard Replacement: adım 6, 3 resimden 3.
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
  7. Palm Pre 2 Motherboard Replacement: adım 7, 1 resimden 1.
    • Use tweezers to separate the keyboard from the phone.
  8. Palm Pre 2 Motherboard Replacement: adım 8, 2 resimden 1. Palm Pre 2 Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the remaining 4 screws from the main portion of the phone.
    • Use an opening tool to remove the motherboard.
Sonuç
Cole Simmerman
160 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G6, Freund Spring 2018 IUPUI, Team S1-G6, Freund Spring 2018 üyesi
IUPUI-FREUND-S18S1G6
2 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 297
