Ana içeriğe geç
Palm Pre Keypad Control Board Replacement
Neye ihtiyacın var
  1. Palm Pre Keypad Control Board Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Pre Keypad Control Board Replacement: adım 2, 1 resimden 1.
    • Carefully pull up on the tab to remove the current battery.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Pre Keypad Control Board Replacement, Antenna: adım 3, 2 resimden 1. Palm Pre Keypad Control Board Replacement, Antenna: adım 3, 2 resimden 2.
    • Use the T5 Torx Screwdriver to remove the six screws holding the backing frame in place.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Pre Keypad Control Board Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the hinge that covers the black and white GPS and DIV antennas. (The hinge will be located in the red box as portrayed in the picture.)
    • Use a spudger to pry open the hinge.
    • Use tweezers to disconnect the antennas from the keypad control board.
    FixBot'a Sor
    Yorum Ekle
  5. Palm Pre Keypad Control Board Replacement: adım 5, 2 resimden 1. Palm Pre Keypad Control Board Replacement: adım 5, 2 resimden 2.
    • Use a spudger to pry off the (black and yellow) back frame.
    • Disregard the main part of the phone at this point and look only at the inside of the removed back frame. (You will need the main part of the phone for access to the keyboard and motherboard)
    FixBot'a Sor
    Yorum Ekle
  6. Palm Pre Keypad Control Board Replacement: adım 6, 1 resimden 1.
    • Find the small circuit board at the top right and desolder the wires that are connected to it.
    • This step is only necessary for antenna removal.
    FixBot'a Sor
    Yorum Ekle
  7. Palm Pre Keypad Control Board Replacement, Keypad Control Board: adım 7, 1 resimden 1.
    • Remove the two ribbon cable connectors using tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. Palm Pre Keypad Control Board Replacement: adım 8, 2 resimden 1. Palm Pre Keypad Control Board Replacement: adım 8, 2 resimden 2.
    • Use a spudger to remove the keypad control board.
    • There is heavy adhesive connecting this part to the keypad sensors.
    FixBot'a Sor
    Yorum Ekle
Sonuç
noha
139 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G31
3 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 40
Her zaman: 1,083
