Ana içeriğe geç
Palm Pre Speaker Replacement
Neye ihtiyacın var
  1. Palm Pre Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Pre Speaker Replacement: adım 2, 1 resimden 1.
    • Carefully pull up on the tab to remove the current battery.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Pre Speaker Replacement, Speaker: adım 3, 2 resimden 1. Palm Pre Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Pre Speaker Replacement: adım 4, 2 resimden 1. Palm Pre Speaker Replacement: adım 4, 2 resimden 2.
    • Use the spudger to locate the crease at the bottom of the keyboard.
    • Carefully work your way around the phone separating the back frame from the keyboard.
    FixBot'a Sor
    Yorum Ekle
  5. Palm Pre Speaker Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. Palm Pre Speaker Replacement: adım 6, 1 resimden 1.
    • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
    • Make sure to take note of the orientation of the speaker for re-installation.
    • Make sure not the puncture the screen on the outside of the back frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
noha
139 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G31
3 Üyeler
44 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,514
