Ana içeriğe geç
Palm Pre Volume Button Replacement
Neye ihtiyacın var
  1. Palm Pre Volume Button Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Pre Volume Button Replacement: adım 2, 1 resimden 1.
    • Carefully pull up on the tab to remove the current battery.
    FixBot'a Sor
    Yorum Ekle
    • Locate the volume cavity on the right of the back frame.
    FixBot'a Sor
    Yorum Ekle
    • Take your new volume button and slide in into the slot until the opposite end clicks.
    • You will have to use some force to do so.
    FixBot'a Sor
    Yorum Ekle
Sonuç
noha
139 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-31, Maness Spring 2012 Cal Poly, Team 7-31, Maness Spring 2012 üyesi
CPSU-MANESS-S12S7G31
3 Üyeler
44 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 609
