Ana içeriğe geç
Palm TX Motherboard Replacement
Neye ihtiyacın var
  1. Palm TX Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Palm TX Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Motherboard Replacement: adım 2, 1 resimden 1.
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Motherboard Replacement: adım 3, 2 resimden 1. Palm TX Motherboard Replacement: adım 3, 2 resimden 2.
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Motherboard Replacement: adım 4, 2 resimden 1. Palm TX Motherboard Replacement: adım 4, 2 resimden 2.
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Motherboard Replacement: adım 5, 2 resimden 1. Palm TX Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Motherboard Replacement, Battery Pack: adım 6, 2 resimden 1. Palm TX Motherboard Replacement, Battery Pack: adım 6, 2 resimden 2.
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Palm TX Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Motherboard Replacement: adım 8, 2 resimden 1. Palm TX Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
Sonuç
Spencer Lewson
793 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-15, Amido Winter 2011 Cal Poly, Team 1-15, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S1G15
4 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 3,429
