Ana içeriğe geç
Palm Treo 600 Battery Replacement
Neye ihtiyacın var
  1. Palm Treo 600 Battery Replacement, Back Case: adım 1, 1 resimden 1.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Treo 600 Battery Replacement: adım 2, 2 resimden 1. Palm Treo 600 Battery Replacement: adım 2, 2 resimden 2.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Treo 600 Battery Replacement: adım 3, 2 resimden 1. Palm Treo 600 Battery Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Treo 600 Battery Replacement, Battery: adım 4, 2 resimden 1. Palm Treo 600 Battery Replacement, Battery: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using metal tweezers, unplug small white plug.
    • Pulling the white plug will disconnect the battery. Make sure the phone is off before you do this step.
    FixBot'a Sor
    Yorum Ekle
  5. Palm Treo 600 Battery Replacement: adım 5, 1 resimden 1.
    • Slide the flat side of the spudger under the battery and gently dislodge the battery by lifting the spudger up.
    • The battery may be glued to the phone.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Clement Poisson
24 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G23
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 6,125
