Ana içeriğe geç
Palm Treo 600 Camera Replacement
Neye ihtiyacın var
  1. Palm Treo 600 Camera Replacement, Back Case: adım 1, 1 resimden 1.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Camera Replacement: adım 2, 2 resimden 1. Palm Treo 600 Camera Replacement: adım 2, 2 resimden 2.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Camera Replacement: adım 3, 2 resimden 1. Palm Treo 600 Camera Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Camera Replacement, Motherboard: adım 4, 1 resimden 1.
    • Using the Phillips #00 screwdriver, unscrew the 4 screws holding the silver casing down.
  5. Palm Treo 600 Camera Replacement: adım 5, 1 resimden 1.
    • Lift up the silver casing.
    • Careful! The casing is connected to the body. Pull the casing up.
  6. Palm Treo 600 Camera Replacement: adım 6, 1 resimden 1.
    • With the silver casing removed, unscrew two black screws with a #00 Phillips Screwdriver.
  7. Palm Treo 600 Camera Replacement: adım 7, 2 resimden 1. Palm Treo 600 Camera Replacement: adım 7, 2 resimden 2.
    • Use the spudger to lift the logic board from its socket. Remove it from the rest of the phone.
  8. Palm Treo 600 Camera Replacement, Camera: adım 8, 2 resimden 1. Palm Treo 600 Camera Replacement, Camera: adım 8, 2 resimden 2.
    • Using the flat end of the spudger, lift the metal case off of the camera.
  9. Palm Treo 600 Camera Replacement: adım 9, 3 resimden 1. Palm Treo 600 Camera Replacement: adım 9, 3 resimden 2. Palm Treo 600 Camera Replacement: adım 9, 3 resimden 3.
    • Slide the flat end of the spudger between the printed circuit board and metal holder.
    • Pop the camera up
Sonuç
Clement Poisson
24 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G23
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,552
