Ana içeriğe geç
Palm Treo 600 Keyboard Replacement
Neye ihtiyacın var
  1. Palm Treo 600 Keyboard Replacement, Back Case: adım 1, 1 resimden 1.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Keyboard Replacement: adım 2, 2 resimden 1. Palm Treo 600 Keyboard Replacement: adım 2, 2 resimden 2.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Keyboard Replacement: adım 3, 2 resimden 1. Palm Treo 600 Keyboard Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Keyboard Replacement, Front Case: adım 4, 2 resimden 1. Palm Treo 600 Keyboard Replacement, Front Case: adım 4, 2 resimden 2.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Palm Treo 600 Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Using the spudger, flip open the clasp that holds the data ribbon in place.
  6. Palm Treo 600 Keyboard Replacement: adım 6, 1 resimden 1.
    • Pull out the ribbon.
    • The keyboard will disconnect from the phone.
Sonuç
Clement Poisson
24 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G23
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,500
