Ana içeriğe geç
Palm Treo 600 Screen Replacement
Neye ihtiyacın var
  1. Palm Treo 600 Screen Replacement, Back Case: adım 1, 1 resimden 1.
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Screen Replacement: adım 2, 2 resimden 1. Palm Treo 600 Screen Replacement: adım 2, 2 resimden 2.
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Screen Replacement: adım 3, 2 resimden 1. Palm Treo 600 Screen Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Screen Replacement, Front Case: adım 4, 2 resimden 1. Palm Treo 600 Screen Replacement, Front Case: adım 4, 2 resimden 2.
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
  5. Palm Treo 600 Screen Replacement, Screen: adım 5, 1 resimden 1.
    • The screen is connected to the phone with an orange data cable.
    • Slide the spudger as close to the connection as possible.
    • Gently pull the spudger up and the cable should come out of the socket.
  6. Palm Treo 600 Screen Replacement: adım 6, 2 resimden 1. Palm Treo 600 Screen Replacement: adım 6, 2 resimden 2.
    • Once the cable is unplugged, you can remove the screen from the body.
Sonuç
Clement Poisson
24 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-23, Maness Winter 2010 Cal Poly, Team 13-23, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G23
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 2,203
