Ana içeriğe geç
Palm Treo 650 Earphone Replacement
Neye ihtiyacın var
  1. Palm Treo 650 Earphone Replacement, Battery and Stylus: adım 1, 1 resimden 1.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Earphone Replacement: adım 2, 1 resimden 1.
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Earphone Replacement: adım 3, 2 resimden 1. Palm Treo 650 Earphone Replacement: adım 3, 2 resimden 2.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Earphone Replacement, Case: adım 4, 1 resimden 1.
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Earphone Replacement: adım 5, 2 resimden 1. Palm Treo 650 Earphone Replacement: adım 5, 2 resimden 2.
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Earphone Replacement: adım 6, 1 resimden 1.
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Earphone Replacement: adım 7, 2 resimden 1. Palm Treo 650 Earphone Replacement: adım 7, 2 resimden 2.
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Earphone Replacement, Motherboard: adım 8, 3 resimden 1. Palm Treo 650 Earphone Replacement, Motherboard: adım 8, 3 resimden 2. Palm Treo 650 Earphone Replacement, Motherboard: adım 8, 3 resimden 3.
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Earphone Replacement: adım 9, 2 resimden 1. Palm Treo 650 Earphone Replacement: adım 9, 2 resimden 2.
    • Pull off the motherboard.
  10. Palm Treo 650 Earphone Replacement, Earphone: adım 10, 3 resimden 1. Palm Treo 650 Earphone Replacement, Earphone: adım 10, 3 resimden 2. Palm Treo 650 Earphone Replacement, Earphone: adım 10, 3 resimden 3.
    • Pull out the earphone by grabbing the black rubber piece identified in the picture.
Sonuç
cgood
122 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S19G3
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 3,005
