Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
A guide for removing and replacing the phone's microphone.
  1. Position the phone so the screen faces down.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. To remove the battery cover, hold down the button in the middle of the phone's back.
    • To remove the battery cover, hold down the button in the middle of the phone's back.
    • Slide the cover down to remove. Set the cover aside.
  3. Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Remove the small round rubber cover on the back of the phone located immediately below the antenna.
    • Remove the small round rubber cover on the back of the phone located immediately below the antenna.
    • This will uncover a screw that will be removed in the next step.
  5. Unscrew the screws around the back plate with a T5 Torx Screwdriver. Six black 6.9 mm Torx screws
    • Unscrew the screws around the back plate with a T5 Torx Screwdriver.
    • Six black 6.9 mm Torx screws
    • Unscrew the screw next to the antennae on the back plate.
    • One 9.75 mm Phillips antenna screw with a Phillips #00 Screwdriver.
  6. Remove the antennae.
    • Remove the antennae.
  7. Pry the back cover off using a spudger or similar tool. The back cover is attached by several small clips on the inside.
    • Pry the back cover off using a spudger or similar tool.
    • The back cover is attached by several small clips on the inside.
  8. Disconnect the ribbon cable before removing the motherboard. Unclip the gray tab. Pull out the orange ribbon cable.
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Pull off the mother board. Install replacement or repaired motherboard, reversing steps above.
    • Pull off the mother board.
    • Install replacement or repaired motherboard, reversing steps above.
  10. Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
    • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  11. Pull off the circuit board.
    • Pull off the circuit board.
  12. Remove the keypad for cleaning or replacing.
    • Remove the keypad for cleaning or replacing.
  13. Place the circuit board with the microphone facing up.
    • Place the circuit board with the microphone facing up.
  14. The microphone should be able to pop off easily using your finger. The microphone should be able to pop off easily using your finger.
    • The microphone should be able to pop off easily using your finger.
Sonuç
cgood
122 İtibar
7 adet Kılavuz yazıldı
Takım
Cal Poly, Team 19-3, Maness Fall 2009 Cal Poly, Team 19-3, Maness Fall 2009 üyesi
CPSU-MANESS-F09S19G3
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,403
