Ana içeriğe geç
Palm Treo 680 Keyboard Replacement
Neye ihtiyacın var
  1. Palm Treo 680 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Palm Treo 680 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Keyboard Replacement, Back Panel: adım 3, 2 resimden 1. Palm Treo 680 Keyboard Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Keyboard Replacement: adım 4, 2 resimden 1. Palm Treo 680 Keyboard Replacement: adım 4, 2 resimden 2.
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Keyboard Replacement: adım 6, 3 resimden 1. Palm Treo 680 Keyboard Replacement: adım 6, 3 resimden 2. Palm Treo 680 Keyboard Replacement: adım 6, 3 resimden 3.
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Keyboard Replacement, Motherboard: adım 7, 2 resimden 1. Palm Treo 680 Keyboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Slide the slim metal plate upwards until it disconnects from the motherboard.
    • DO NOT bend or crinkle this metal plate. It will be VERY DIFFICULT, IF NOT IMPOSSIBLE, to slide it back into place when you are re-assembling if you bend or crinkle this metal plate.
  8. Palm Treo 680 Keyboard Replacement: adım 8, 2 resimden 1. Palm Treo 680 Keyboard Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the orange ribbon that connects the screen to the motherboard.
    • Use tweezers to peel off the small piece of tape over the orange ribbon connector.
  9. Palm Treo 680 Keyboard Replacement: adım 9, 2 resimden 1. Palm Treo 680 Keyboard Replacement: adım 9, 2 resimden 2.
    • Slide the spudger between the orange ribbon and black connector. Flip the black connector upwards to release the orange ribbon.
    • Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
  10. Palm Treo 680 Keyboard Replacement: adım 10, 3 resimden 1. Palm Treo 680 Keyboard Replacement: adım 10, 3 resimden 2. Palm Treo 680 Keyboard Replacement: adım 10, 3 resimden 3.
    • Carefully turn the phone over so the screen is face up.
    • Locate the other orange ribbon that connects the motherboard to the faceplate.
    • Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
    • Separate the motherboard and faceplate of the Palm Treo.
  11. Palm Treo 680 Keyboard Replacement, Keyboard: adım 11, 2 resimden 1. Palm Treo 680 Keyboard Replacement, Keyboard: adım 11, 2 resimden 2.
    • Locate the backside of the Treo's faceplate.
    • Remove the two screws using the T6 Torx screwdriver.
  12. Palm Treo 680 Keyboard Replacement: adım 12, 2 resimden 1. Palm Treo 680 Keyboard Replacement: adım 12, 2 resimden 2.
    • Take off the plastic back panel, to gain access to the rubber keys of the keyboard.
    • Push on the keys and function bar from the front of the Treo. They should all pop right out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maiya123
84 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-4, Maness Fall 2009 Cal Poly, Team 6-4, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G4
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 4,862
