Giriş
This is a guide that indicates how to replace a faulty microphone for the Palm Treo 680.
Parçalar
Hiçbir parçaya gerek yok.
Remove the battery cover by pressing on the small rectangular button location the back of the phone.
Remove the battery by pulling it out toward you.
Unscrew the 0.266 inch top-left screw with a T6 Torx Screwdriver.
Use a T5 Torx screwdriver instead of a T6. T6 is too big.
I found T5 too large as well. T4 seeems to work
Using the spudger, remove the rubber rectangular cover located in the upper right hand side of the device.
Unscrew the 0.266 inch screw with the T6 Torx Screwdriver.
Remove the remaining two 0.266 inch screws at the bottom of the device.
Turn the phone 90 degrees to the right, so the screen is facing the right side.
Use a spudger to carefully separate the back panel from the front panel to access all the various components inside the phone.
Using a pair of tweezers, grasp the blue rubber microphone.
Pull the rubber microphone up and back to remove it.
Now you have successfully removed the microphone.
2 başka kişi bu kılavuzu tamamladı.
