Ana içeriğe geç
Palm Treo 680 Microphone Replacement
Neye ihtiyacın var
  1. Palm Treo 680 Microphone Replacement, Battery: adım 1, 2 resimden 1. Palm Treo 680 Microphone Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Microphone Replacement, Back Panel: adım 3, 2 resimden 1. Palm Treo 680 Microphone Replacement, Back Panel: adım 3, 2 resimden 2.
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Microphone Replacement: adım 4, 2 resimden 1. Palm Treo 680 Microphone Replacement: adım 4, 2 resimden 2.
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Microphone Replacement: adım 5, 1 resimden 1.
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Microphone Replacement: adım 6, 3 resimden 1. Palm Treo 680 Microphone Replacement: adım 6, 3 resimden 2. Palm Treo 680 Microphone Replacement: adım 6, 3 resimden 3.
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Microphone Replacement, Microphone: adım 7, 2 resimden 1. Palm Treo 680 Microphone Replacement, Microphone: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, grasp the blue rubber microphone.
    • Pull the rubber microphone up and back to remove it.
    • Now you have successfully removed the microphone.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maiya123
84 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-4, Maness Fall 2009 Cal Poly, Team 6-4, Maness Fall 2009 üyesi
CPSU-MANESS-F09S6G4
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 4,176
