Giriş
This guide shows how to replace the motherboard in the Palm Treo 680.
Parçalar
Hiçbir parça belirtilmedi.
Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
Remove the stylus in order to access the screw.
Remove the 27mm top-left screw using a T6 Torx screwdriver.
Slide the slim metal plate upwards until it disconnects from the motherboard.
Carefully turn the phone over so the screen is face up.
Locate the other orange ribbon that connects the motherboard to the faceplate.
Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
Separate the motherboard and faceplate of the Palm Treo.
2 farklı kişi bu kılavuzu tamamladı.
