Ana içeriğe geç
Palm Treo 700P Antenna Replacement
Neye ihtiyacın var
  1. Palm Treo 700P Antenna Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 700P Antenna Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 700P Antenna Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Antenna Replacement: adım 2, 2 resimden 1. Palm Treo 700P Antenna Replacement: adım 2, 2 resimden 2.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Antenna Replacement, Antenna: adım 3, 1 resimden 1.
    • Remove the stylus from the phone.
  4. Palm Treo 700P Antenna Replacement: adım 4, 1 resimden 1.
    • After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
  5. Palm Treo 700P Antenna Replacement: adım 5, 1 resimden 1.
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Antenna Replacement: adım 6, 1 resimden 1.
    • Unscrew the last two screws using the same T-5 Torx screw driver.
  7. Palm Treo 700P Antenna Replacement: adım 7, 1 resimden 1.
    • Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
  8. Palm Treo 700P Antenna Replacement: adım 8, 1 resimden 1.
    • The antenna will now be loose, gently pull the antenna out of the phone.
Sonuç
John Rainier Solanzo
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G37
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 807
