Ana içeriğe geç
Giriş
Follow this guide to access and remove the antenna of the cell phone.
  1. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down. Press the button located just above the Sprint™ logo and then slide the cover down.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Use the small notch on the left hand side of the phone to remove the battery. Use the small notch on the left hand side of the phone to remove the battery.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Remove the stylus from the phone.
    • Remove the stylus from the phone.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
    • After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
  6. Using the spudger, remove the small rubberized patch under the antenna.
    • Using the spudger, remove the small rubberized patch under the antenna.
  7. Unscrew the last two screws using the same T-5 Torx screw driver.
    • Unscrew the last two screws using the same T-5 Torx screw driver.
  8. Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
    • Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
  9. The antenna will now be loose, gently pull the antenna out of the phone.
    • The antenna will now be loose, gently pull the antenna out of the phone.
Sonuç
John Rainier Solanzo
4 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G37
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 1
Her zaman: 698
