Ana içeriğe geç
Palm Treo 700P Camera Replacement
Neye ihtiyacın var
  1. Palm Treo 700P Camera Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 700P Camera Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 700P Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Treo 700P Camera Replacement: adım 2, 2 resimden 1. Palm Treo 700P Camera Replacement: adım 2, 2 resimden 2.
    • Use the small notch on the left hand side of the phone to remove the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Treo 700P Camera Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the stylus from the phone.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Treo 700P Camera Replacement: adım 4, 1 resimden 1.
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
    FixBot'a Sor
    Yorum Ekle
  5. Palm Treo 700P Camera Replacement: adım 5, 1 resimden 1.
    • Using the spudger, remove the small rubberized patch under the antenna.
    FixBot'a Sor
    Yorum Ekle
  6. Palm Treo 700P Camera Replacement: adım 6, 1 resimden 1.
    • Unscrew the last two screws using the previous screw driver.
    FixBot'a Sor
    Yorum Ekle
  7. Palm Treo 700P Camera Replacement: adım 7, 2 resimden 1. Palm Treo 700P Camera Replacement: adım 7, 2 resimden 2.
    • Using the plastic opening tool, gently separate the back case from the phone body.
    FixBot'a Sor
    Yorum Ekle
  8. Palm Treo 700P Camera Replacement, Motherboard: adım 8, 3 resimden 1. Palm Treo 700P Camera Replacement, Motherboard: adım 8, 3 resimden 2. Palm Treo 700P Camera Replacement, Motherboard: adım 8, 3 resimden 3.
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
    FixBot'a Sor
    Yorum Ekle
  9. Palm Treo 700P Camera Replacement: adım 9, 3 resimden 1. Palm Treo 700P Camera Replacement: adım 9, 3 resimden 2. Palm Treo 700P Camera Replacement: adım 9, 3 resimden 3.
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
    FixBot'a Sor
    Yorum Ekle
  10. Palm Treo 700P Camera Replacement: adım 10, 2 resimden 1. Palm Treo 700P Camera Replacement: adım 10, 2 resimden 2.
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
    FixBot'a Sor
    Yorum Ekle
  11. Palm Treo 700P Camera Replacement: adım 11, 3 resimden 1. Palm Treo 700P Camera Replacement: adım 11, 3 resimden 2. Palm Treo 700P Camera Replacement: adım 11, 3 resimden 3.
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
    FixBot'a Sor
    Yorum Ekle
  12. Palm Treo 700P Camera Replacement, Camera: adım 12, 1 resimden 1.
    • Using the plastic opening tool, loosen the metal camera holder.
    FixBot'a Sor
    Yorum Ekle
  13. Palm Treo 700P Camera Replacement: adım 13, 1 resimden 1.
    • Once the camera holder is loose, gently detach it from the camera.
    FixBot'a Sor
    Yorum Ekle
Sonuç
John Rainier Solanzo
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G37
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Does anyone know where or how to get a developers guide or geeks guide to tearing this phone down completely? I have a number of these, as well as old Galaxy Note phones, a broken S7 etc. And I would love to have the blueprint to know how to hack a LTE antenae, and S7 camera into my treo palm 700p..Wouldn't that be awesome? I still like it better than the modern smart phone, and just lost use of it when my carrier killed CDMA last week> :-(
peterveri - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 897
