Ana içeriğe geç
Palm Treo 700P Camera Replacement
Neye ihtiyacın var
  1. Palm Treo 700P Camera Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 700P Camera Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 700P Camera Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Camera Replacement: adım 2, 2 resimden 1. Palm Treo 700P Camera Replacement: adım 2, 2 resimden 2.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Camera Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the stylus from the phone.
  4. Palm Treo 700P Camera Replacement: adım 4, 1 resimden 1.
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P Camera Replacement: adım 5, 1 resimden 1.
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Camera Replacement: adım 6, 1 resimden 1.
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P Camera Replacement: adım 7, 2 resimden 1. Palm Treo 700P Camera Replacement: adım 7, 2 resimden 2.
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P Camera Replacement, Motherboard: adım 8, 3 resimden 1. Palm Treo 700P Camera Replacement, Motherboard: adım 8, 3 resimden 2. Palm Treo 700P Camera Replacement, Motherboard: adım 8, 3 resimden 3.
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P Camera Replacement: adım 9, 3 resimden 1. Palm Treo 700P Camera Replacement: adım 9, 3 resimden 2. Palm Treo 700P Camera Replacement: adım 9, 3 resimden 3.
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P Camera Replacement: adım 10, 2 resimden 1. Palm Treo 700P Camera Replacement: adım 10, 2 resimden 2.
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P Camera Replacement: adım 11, 3 resimden 1. Palm Treo 700P Camera Replacement: adım 11, 3 resimden 2. Palm Treo 700P Camera Replacement: adım 11, 3 resimden 3.
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
  12. Palm Treo 700P Camera Replacement, Camera: adım 12, 1 resimden 1.
    • Using the plastic opening tool, loosen the metal camera holder.
  13. Palm Treo 700P Camera Replacement: adım 13, 1 resimden 1.
    • Once the camera holder is loose, gently detach it from the camera.
Sonuç
John Rainier Solanzo
7 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G37
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Does anyone know where or how to get a developers guide or geeks guide to tearing this phone down completely? I have a number of these, as well as old Galaxy Note phones, a broken S7 etc. And I would love to have the blueprint to know how to hack a LTE antenae, and S7 camera into my treo palm 700p..Wouldn't that be awesome? I still like it better than the modern smart phone, and just lost use of it when my carrier killed CDMA last week> :-(
peterveri - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 18
Her zaman: 584
