Ana içeriğe geç
Palm Treo 700P Keypad Replacement
Neye ihtiyacın var
  1. Palm Treo 700P Keypad Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 700P Keypad Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 700P Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button located just above the Sprint™ logo and then slide the cover down.
  2. Palm Treo 700P Keypad Replacement: adım 2, 2 resimden 1. Palm Treo 700P Keypad Replacement: adım 2, 2 resimden 2.
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Keypad Replacement, Back Case: adım 3, 1 resimden 1.
    • Remove the stylus from the phone.
  4. Palm Treo 700P Keypad Replacement: adım 4, 1 resimden 1.
    • After removing the battery and stylus, unscrew the 5 Torx screws (using a T-5 Torx screw driver)
  5. Palm Treo 700P Keypad Replacement: adım 5, 1 resimden 1.
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Keypad Replacement: adım 6, 1 resimden 1.
    • Unscrew the last two screws using the previous screw driver.
  7. Palm Treo 700P Keypad Replacement: adım 7, 2 resimden 1. Palm Treo 700P Keypad Replacement: adım 7, 2 resimden 2.
    • Using the plastic opening tool, gently separate the back case from the phone body.
  8. Palm Treo 700P Keypad Replacement, Motherboard: adım 8, 3 resimden 1. Palm Treo 700P Keypad Replacement, Motherboard: adım 8, 3 resimden 2. Palm Treo 700P Keypad Replacement, Motherboard: adım 8, 3 resimden 3.
    • Using a plastic opening tool, gently edge your way between the back and border case (Picture 2) until they are completely separated (Picture 3).
  9. Palm Treo 700P Keypad Replacement: adım 9, 3 resimden 1. Palm Treo 700P Keypad Replacement: adım 9, 3 resimden 2. Palm Treo 700P Keypad Replacement: adım 9, 3 resimden 3.
    • Remove the antenna chip by unscrewing the two screws with Torx T-5 screwdriver (Picture 1).
    • Once unscrewed, gently detach the antenna chip with your hands (Picture 2).
  10. Palm Treo 700P Keypad Replacement: adım 10, 2 resimden 1. Palm Treo 700P Keypad Replacement: adım 10, 2 resimden 2.
    • Use the plastic opening tool to unlock the tab holding the keyboard connection (Picture 1).
    • Once the keyboard connection is detached, use your hands to gently separate the motherboard from the back panel (Picture 2).
  11. Palm Treo 700P Keypad Replacement: adım 11, 3 resimden 1. Palm Treo 700P Keypad Replacement: adım 11, 3 resimden 2. Palm Treo 700P Keypad Replacement: adım 11, 3 resimden 3.
    • To completely detach the motherboard from the back panel, use the plastic opening tool to unlock the LCD connection from the motherboard (Picture 2).
    • Once the LCD connection is unlocked, the motherboard should now be completely detached from the back panel, keyboard, and LCD (Picture 3).
  12. Palm Treo 700P Keypad Replacement, LCD: adım 12, 1 resimden 1.
    • Once the motherboard is removed, the LCD should be resting on the front case of the phone.
  13. Palm Treo 700P Keypad Replacement, Keypad: adım 13, 1 resimden 1.
    • Peel the keypad from the front panel of the case
  14. Palm Treo 700P Keypad Replacement: adım 14, 1 resimden 1.
    • Using a spudger, remove the gel keyboard from the front case.
Sonuç
James Smith
10 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-37, Regan Spring 2012 Cal Poly, Team 12-37, Regan Spring 2012 üyesi
CPSU-REGAN-S12S12G37
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 701
