Ana içeriğe geç
Palm Treo 755p Screen Replacement
Neye ihtiyacın var
  1. Palm Treo 755p Screen Replacement, Battery: adım 1, 3 resimden 1. Palm Treo 755p Screen Replacement, Battery: adım 1, 3 resimden 2. Palm Treo 755p Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Treo 755p Screen Replacement: adım 2, 2 resimden 1. Palm Treo 755p Screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery by lifting up on one side.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Treo 755p Screen Replacement, Back Cover: adım 3, 2 resimden 1. Palm Treo 755p Screen Replacement, Back Cover: adım 3, 2 resimden 2.
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Treo 755p Screen Replacement: adım 4, 1 resimden 1.
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
    FixBot'a Sor
    Yorum Ekle
  5. Palm Treo 755p Screen Replacement: adım 5, 2 resimden 1. Palm Treo 755p Screen Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
    FixBot'a Sor
    Yorum Ekle
  6. Palm Treo 755p Screen Replacement: adım 6, 2 resimden 1. Palm Treo 755p Screen Replacement: adım 6, 2 resimden 2.
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
    FixBot'a Sor
    Yorum Ekle
  7. Palm Treo 755p Screen Replacement: adım 7, 3 resimden 1. Palm Treo 755p Screen Replacement: adım 7, 3 resimden 2. Palm Treo 755p Screen Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
    FixBot'a Sor
    Yorum Ekle
  8. Palm Treo 755p Screen Replacement, Circuit Board: adım 8, 1 resimden 1.
    • Gently peel off the protective yellow tape covering the ribbon cable using tweezers or your fingers.
    • ATTENTION: Save the tape for reassembly.
    FixBot'a Sor
    Yorum Ekle
  9. Palm Treo 755p Screen Replacement: adım 9, 2 resimden 1. Palm Treo 755p Screen Replacement: adım 9, 2 resimden 2.
    • Using tweezers flip up the black plastic snap covering the small ribbon cable.
    • Using tweezers gently pull out the ribbon cable to detach it from the circuit board.
    FixBot'a Sor
    Yorum Ekle
  10. Palm Treo 755p Screen Replacement: adım 10, 1 resimden 1.
    • With the screen facing down. Use the Phillips 00 screwdriver attachment to remove the silver, 0.124 inch long screw on the left side of the circuit board above the ribbon cable.
    • WARNING: Do not over-tighten the screw during reassembly.
    FixBot'a Sor
    Yorum Ekle
  11. Palm Treo 755p Screen Replacement: adım 11, 3 resimden 1. Palm Treo 755p Screen Replacement: adım 11, 3 resimden 2. Palm Treo 755p Screen Replacement: adım 11, 3 resimden 3.
    • Pivot the circuit board away from the casing keeping the screen face down.
    • Gently peel away the tape holding the ribbon cable to the screen.
    FixBot'a Sor
    Yorum Ekle
  12. Palm Treo 755p Screen Replacement: adım 12, 2 resimden 1. Palm Treo 755p Screen Replacement: adım 12, 2 resimden 2.
    • Using tweezers flip up the black plastic snap covering the ribbon cable attached to the screen.
    • Gently pull out the ribbon cable freeing the circuit board from the casing.
    FixBot'a Sor
    Yorum Ekle
  13. Palm Treo 755p Screen Replacement: adım 13, 2 resimden 1. Palm Treo 755p Screen Replacement: adım 13, 2 resimden 2.
    • Separate the circuit board from front cover.
    FixBot'a Sor
    Yorum Ekle
  14. Palm Treo 755p Screen Replacement, Screen: adım 14, 2 resimden 1. Palm Treo 755p Screen Replacement, Screen: adım 14, 2 resimden 2.
    • Using your fingers gently lift the display screen panel out of the casing by either grasping it from the back or popping it out of the front.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Mike Shaw
601 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-6, Forte Winter 2011 Cal Poly, Team 14-6, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G6
6 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 2,261
