Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
A guide to help you replace the screen in your Palm Treo Pro.
Neye ihtiyacın var
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use a plastic opening tool to lift the motherboard up and out of the phone case
There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
It can easily be disconnected with your fingers
The motherboard has now been completely removed
Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
Bir başkası bu kılavuzu tamamladı.
