Giriş
The following 11 steps will help you replace a faulty motherboard with a new one.
Neye ihtiyacın var
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use a plastic opening tool to lift the motherboard up and out of the phone case
There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
It can easily be disconnected with your fingers
The motherboard has now been completely removed
Bir başkası bu kılavuzu tamamladı.
