Ana içeriğe geç
Palm Treo Pro Motherboard Replacement
Neye ihtiyacın var
  1. Palm Treo Pro Motherboard Replacement, Battery: adım 1, 3 resimden 1. Palm Treo Pro Motherboard Replacement, Battery: adım 1, 3 resimden 2. Palm Treo Pro Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Press down on the back of the case and slide forward to remove it.
  2. Palm Treo Pro Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pulling up on the tab near the camera lens.
    • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
  3. Palm Treo Pro Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Palm Treo Pro Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Palm Treo Pro Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
    • Be careful not to misplace these screws as they are very small and will be important during reassembly.
    • If the screws are stripped a flat head screw driver may be necessary.
  4. Palm Treo Pro Motherboard Replacement: adım 4, 3 resimden 1. Palm Treo Pro Motherboard Replacement: adım 4, 3 resimden 2. Palm Treo Pro Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
  5. Palm Treo Pro Motherboard Replacement: adım 5, 3 resimden 1. Palm Treo Pro Motherboard Replacement: adım 5, 3 resimden 2. Palm Treo Pro Motherboard Replacement: adım 5, 3 resimden 3.
    • Remove the main plastic body
    • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
    • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
  6. Palm Treo Pro Motherboard Replacement: adım 6, 3 resimden 1. Palm Treo Pro Motherboard Replacement: adım 6, 3 resimden 2. Palm Treo Pro Motherboard Replacement: adım 6, 3 resimden 3.
    • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
    • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
  7. Palm Treo Pro Motherboard Replacement: adım 7, 2 resimden 1. Palm Treo Pro Motherboard Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
  8. Palm Treo Pro Motherboard Replacement: adım 8, 3 resimden 1. Palm Treo Pro Motherboard Replacement: adım 8, 3 resimden 2. Palm Treo Pro Motherboard Replacement: adım 8, 3 resimden 3.
    • There are two ribbon cables under the yellow tape.
    • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
    • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
  9. Palm Treo Pro Motherboard Replacement: adım 9, 3 resimden 1. Palm Treo Pro Motherboard Replacement: adım 9, 3 resimden 2. Palm Treo Pro Motherboard Replacement: adım 9, 3 resimden 3.
    • Use a plastic opening tool to lift the motherboard up and out of the phone case
    • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
    • It can easily be disconnected with your fingers
    • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
    • The motherboard has now been completely removed
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nadia Carroll
11 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-59, Johann Spring 2013 Cal Poly, Team 8-59, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S8G59
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 365
