Giriş
This guide will walk you through the process of removing the speaker from the phone so that it can be replaced or cleaned.
Neye ihtiyacın var
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use a plastic opening tool to lift the motherboard up and out of the phone case
There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
It can easily be disconnected with your fingers
The motherboard has now been completely removed
Insert your plastic pry in the gap at the top of the phone above the speaker.
Bir başkası bu kılavuzu tamamladı.
