Ana içeriğe geç
Palm Zire 31 Keys Replacement
Neye ihtiyacın var
  1. Palm Zire 31 Keys Replacement, Case: adım 1, 1 resimden 1.
    • Unscrew the two 7.35mm Torx T6 screws.
    FixBot'a Sor
    Yorum Ekle
  2. Palm Zire 31 Keys Replacement: adım 2, 1 resimden 1.
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
    FixBot'a Sor
    Yorum Ekle
  3. Palm Zire 31 Keys Replacement: adım 3, 1 resimden 1.
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
    FixBot'a Sor
    Yorum Ekle
  4. Palm Zire 31 Keys Replacement: adım 4, 1 resimden 1.
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
    FixBot'a Sor
    Yorum Ekle
  5. Palm Zire 31 Keys Replacement, Keys: adım 5, 1 resimden 1.
    • The blue keys will either come off with the blue front case, or stay on the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Gabe
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-21, Amido Winter 2011 Cal Poly, Team 5-21, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G21
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 36
Her zaman: 912
