Ana içeriğe geç
Palm Zire 31 Speaker Replacement
Neye ihtiyacın var
  1. Palm Zire 31 Speaker Replacement, Case: adım 1, 1 resimden 1.
    • Unscrew the two 7.35mm Torx T6 screws.
  2. Palm Zire 31 Speaker Replacement: adım 2, 1 resimden 1.
    • Using the flat end of the spudger, carefully pry the black cover on the top from the blue front cover.
  3. Palm Zire 31 Speaker Replacement: adım 3, 1 resimden 1.
    • Carefully remove the speaker from the back white cover by just pulling it gently. It is glued on.
  4. Palm Zire 31 Speaker Replacement: adım 4, 1 resimden 1.
    • Unscrew the #00 5.75mm Phillips screws from the bottom of the motherboard. The front blue panel should fall right off.
  5. Palm Zire 31 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • The soldering iron heats up leads, wires, and everything else it touches that is metal. Leaving it on too long may damage the board or burn you.
    • Desolder the speaker wires and solder the new speaker in its place.
    • The black and red wires are connected to the two solder bulbs in the yellow box.
Sonuç
Gabe
501 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-21, Amido Winter 2011 Cal Poly, Team 5-21, Amido Winter 2011 üyesi
CPSU-AMIDO-W11S5G21
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 605
