Ana içeriğe geç
Palm Zire 71 Back Cover Replacement
Neye ihtiyacın var
  1. Palm Zire 71 Back Cover Replacement, Preparation: adım 1, 1 resimden 1.
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Back Cover Replacement, Top Screws (2) Removal: adım 2, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Back Cover Replacement, Bottom Screws (3) Removal: adım 3, 1 resimden 1.
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Back Cover Replacement, Front Panel Removal: adım 4, 2 resimden 1. Palm Zire 71 Back Cover Replacement, Front Panel Removal: adım 4, 2 resimden 2.
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: adım 5, 2 resimden 1. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: adım 5, 2 resimden 2.
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Back Cover Replacement, Back Cover: adım 6, 2 resimden 1. Palm Zire 71 Back Cover Replacement, Back Cover: adım 6, 2 resimden 2.
    • Slide the back cover off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jinxian Jiang
245 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-5, Nelson Spring 2011 CSU Los Angeles, Team 1-5, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,478
