Ana içeriğe geç
Palm Zire 71 Motherboard/Screen Replacement
Neye ihtiyacın var
  1. Palm Zire 71 Motherboard/Screen Replacement, Preparation: adım 1, 1 resimden 1.
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Motherboard/Screen Replacement, Top Screws (2) Removal: adım 2, 1 resimden 1.
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Motherboard/Screen Replacement, Bottom Screws (3) Removal: adım 3, 1 resimden 1.
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: adım 4, 2 resimden 1. Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: adım 4, 2 resimden 2.
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: adım 5, 2 resimden 1. Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: adım 5, 2 resimden 2.
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Motherboard/Screen Replacement, Back Cover: adım 6, 2 resimden 1. Palm Zire 71 Motherboard/Screen Replacement, Back Cover: adım 6, 2 resimden 2.
    • Slide the back cover off.
  7. Palm Zire 71 Motherboard/Screen Replacement, Battery: adım 7, 1 resimden 1.
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Motherboard/Screen Replacement: adım 8, 2 resimden 1. Palm Zire 71 Motherboard/Screen Replacement: adım 8, 2 resimden 2.
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Motherboard/Screen Replacement: adım 9, 3 resimden 1. Palm Zire 71 Motherboard/Screen Replacement: adım 9, 3 resimden 2. Palm Zire 71 Motherboard/Screen Replacement: adım 9, 3 resimden 3.
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Motherboard/Screen Replacement: adım 10, 3 resimden 1. Palm Zire 71 Motherboard/Screen Replacement: adım 10, 3 resimden 2. Palm Zire 71 Motherboard/Screen Replacement: adım 10, 3 resimden 3.
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
  11. Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: adım 11, 2 resimden 1. Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: adım 11, 2 resimden 2.
    • Remove Philips screw #00
    • Remove black plastic top part
  12. Palm Zire 71 Motherboard/Screen Replacement: adım 12, 3 resimden 1. Palm Zire 71 Motherboard/Screen Replacement: adım 12, 3 resimden 2. Palm Zire 71 Motherboard/Screen Replacement: adım 12, 3 resimden 3.
    • Pull off the orange cable
    • Now the screen and the motherboard can be separated
    • Finished
Sonuç
Jinxian Jiang
272 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-5, Nelson Spring 2011 CSU Los Angeles, Team 1-5, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 2,873
