Ana içeriğe geç
Palm Zire m150 Motherboard Replacement
Neye ihtiyacın var
  1. Palm Zire m150 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Lift up the flap on the Palm Zire M150.
    • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
    • If you wish to remove it, gently lift up and pull horizontally. It should come off without an issue.
  2. Palm Zire m150 Motherboard Replacement: adım 2, 1 resimden 1.
    • Take the screwdriver from the IFixit toolkit and use the T6 bit. Unscrew the the top two 3mm screws above where the flap was connected to the device.
  3. Palm Zire m150 Motherboard Replacement: adım 3, 2 resimden 1. Palm Zire m150 Motherboard Replacement: adım 3, 2 resimden 2.
    • Gently pull the top cover off the device using both hands.
  4. Palm Zire m150 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the screen from the motherboard.
    • Be careful not to break the connector that connects the screen to motherboard.
  5. Palm Zire m150 Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully remove the battery by prying up away from the motherboard.
    • Battery is glued to motherboard.
    • Remove the positive and negative terminals from the motherboard.
    • Slowly remove the motherboard by lifting upward and out of the bottom case housing.
  6. Palm Zire m150 Motherboard Replacement: adım 6, 2 resimden 1. Palm Zire m150 Motherboard Replacement: adım 6, 2 resimden 2.
    • Insert NEW motherboard into the bottom case housing.
    • On the NEW motherboard, use a soldering iron to solder the positive and negative terminals to the new motherboard.
    • Let solder cool before reassembling unit.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kate
528 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 441
