Giriş
This guide will provide instructions and visuals to removing and replacing batteries.
  1. Take the battery cover off by pushing down on the tab and lifting off.
    • Take the battery cover off by pushing down on the tab and lifting off.
  2. Make sure batteries are there.
    • Make sure batteries are there.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Check the type of batteries to be sure they are both AAA batteries.
    • Check the type of batteries to be sure they are both AAA batteries.
    • Make sure they are installed in the right direction by taking the batteries out, aligning the positive side with the positive side and the negative side with the negative side.
  5. Once positive that the batteries are installed correctly, press the on/off located at the top center of the device.
    • Once positive that the batteries are installed correctly, press the on/off located at the top center of the device.
    • If the device still does not turn on, repeat the previous steps with a fresh set of AAA batteries.
Sonuç
Anne Carey
1 İtibar
3 adet Kılavuz yazıldı
Takım
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 4
Son 30 Gün: 8
Her zaman: 500
