Ana içeriğe geç
Palm m 100 Cover Replacement
Neye ihtiyacın var
  1. Palm m 100 Cover Replacement, Cover: adım 1, 1 resimden 1.
    • Remove the batteries.
  2. Palm m 100 Cover Replacement: adım 2, 1 resimden 1.
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Cover Replacement: adım 3, 3 resimden 1. Palm m 100 Cover Replacement: adım 3, 3 resimden 2. Palm m 100 Cover Replacement: adım 3, 3 resimden 3.
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  4. Palm m 100 Cover Replacement: adım 4, 1 resimden 1.
    • Set aside broken cover, and replace with a new cover.
  5. Palm m 100 Cover Replacement: adım 5, 1 resimden 1.
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  6. Palm m 100 Cover Replacement: adım 6, 1 resimden 1.
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Sonuç
Anne Carey
1 İtibar
3 adet Kılavuz yazıldı
Ekip
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 10
Her zaman: 547
