Ana içeriğe geç
Palm m 100 Display Screen Replacement
Neye ihtiyacın var
  1. Palm m 100 Display Screen Replacement, Display Screen: adım 1, 1 resimden 1.
    • Remove the batteries.
  2. Palm m 100 Display Screen Replacement: adım 2, 1 resimden 1.
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Display Screen Replacement: adım 3, 1 resimden 1.
    • Remove rear cover by gently lifting it up from the bottom.
  4. Palm m 100 Display Screen Replacement: adım 4, 1 resimden 1.
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Lift the left side of the circuit board and open it as though it were a book.
  5. Palm m 100 Display Screen Replacement: adım 5, 2 resimden 1. Palm m 100 Display Screen Replacement: adım 5, 2 resimden 2.
    • Unplug the three connectors located on the right side of the circuit board with great caution and care.
    • Slide the cables out gently using a spudger
    • Separate the screen from the board.
Sonuç
Lexi Gallucci
11 İtibar
2 adet Kılavuz yazıldı
Ekip
James Madison, Team 1-3, Allen Fall 2011 James Madison, Team 1-3, Allen Fall 2011 üyesi
JMU-ALLEN-F11S1G3
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 724
