Ana içeriğe geç
Palm m105 Display Screen Replacement
Neye ihtiyacın var
  1. Palm m105 Display Screen Replacement, Display Screen: adım 1, 1 resimden 1.
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out
  2. Palm m105 Display Screen Replacement: adım 2, 1 resimden 1.
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off.
  3. Palm m105 Display Screen Replacement: adım 3, 2 resimden 1. Palm m105 Display Screen Replacement: adım 3, 2 resimden 2.
    • Using a a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    • The link to purchase this screwdriver is Located here.
  4. Palm m105 Display Screen Replacement: adım 4, 1 resimden 1.
    • This is what the device looks like once you have taken the screws out and opened the device.
  5. Palm m105 Display Screen Replacement: adım 5, 1 resimden 1.
    • The Motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step, the components are fragile.
  6. Palm m105 Display Screen Replacement: adım 6, 1 resimden 1.
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • ** This step needs to be done with special care because it is very fragile.**
    • Once they are all three popped up the motherboard and screen will separate easily.
  7. Palm m105 Display Screen Replacement: adım 7, 1 resimden 1.
    • Click here for Palm m105 screen replacement
    • Now that the screen and motherboard are separated you may discard the broken screen. The best way to dispose of the broken screen is to: Recycle it
Sonuç
Erik Thompson
31 İtibar
5 adet Kılavuz yazıldı
Ekip
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 664
