Ana içeriğe geç
Palm m105 Motherboard Replacement
Neye ihtiyacın var
  1. Palm m105 Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Start with your intact Palm m105.
    FixBot'a Sor
    Yorum Ekle
  2. Palm m105 Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out.
    FixBot'a Sor
    Yorum Ekle
  3. Palm m105 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off.
    FixBot'a Sor
    Yorum Ekle
  4. Palm m105 Motherboard Replacement: adım 4, 2 resimden 1. Palm m105 Motherboard Replacement: adım 4, 2 resimden 2.
    • Using a T5 Torx screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    FixBot'a Sor
    Yorum Ekle
  5. Palm m105 Motherboard Replacement: adım 5, 1 resimden 1.
    • This is what the device looks like once you have taken the screws out and opened the device.
    FixBot'a Sor
    Yorum Ekle
  6. Palm m105 Motherboard Replacement: adım 6, 1 resimden 1.
    • The motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step; the components are fragile.
    FixBot'a Sor
    Yorum Ekle
  7. Palm m105 Motherboard Replacement: adım 7, 1 resimden 1.
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • This step needs to be done with special care because it is very fragile.
    • Once they are all three popped up the motherboard and screen will separate easily.
    FixBot'a Sor
    Yorum Ekle
  8. Palm m105 Motherboard Replacement: adım 8, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron
22 İtibar
1 Kılavuz yazıldı
Ekip
UW Stout, Team 1-3, Zhou Fall 2011 UW Stout, Team 1-3, Zhou Fall 2011 üyesi
UWSTOUT-ZHOU-F11S1G3
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 47
Her zaman: 1,559
