Ana içeriğe geç
Palm m500 Battery Replacement
Neye ihtiyacın var
  1. Palm m500 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the stylus from the side of the PDA by sliding it upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Palm m500 Battery Replacement: adım 2, 2 resimden 1. Palm m500 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
    FixBot'a Sor
    Yorum Ekle
  3. Palm m500 Battery Replacement: adım 3, 3 resimden 1. Palm m500 Battery Replacement: adım 3, 3 resimden 2. Palm m500 Battery Replacement: adım 3, 3 resimden 3.
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
    FixBot'a Sor
    Yorum Ekle
  4. Palm m500 Battery Replacement, Battery: adım 4, 3 resimden 1. Palm m500 Battery Replacement, Battery: adım 4, 3 resimden 2. Palm m500 Battery Replacement, Battery: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Brandan Williams
172 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Winter 2011 Cal Poly, Team 14-9, Forte Winter 2011 üyesi
CPSU-FORTE-W11S14G9
6 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 62
Her zaman: 6,126
