Ana içeriğe geç
Palm v Outer Case Replacement
Neye ihtiyacın var
  1. Palm v Outer Case Replacement, Outer Case: adım 1, 1 resimden 1.
    • Lay device face down on surface.
  2. Palm v Outer Case Replacement: adım 2, 2 resimden 1. Palm v Outer Case Replacement: adım 2, 2 resimden 2.
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Palm v Outer Case Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  4. Palm v Outer Case Replacement: adım 4, 1 resimden 1.
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  5. Palm v Outer Case Replacement: adım 5, 3 resimden 1. Palm v Outer Case Replacement: adım 5, 3 resimden 2. Palm v Outer Case Replacement: adım 5, 3 resimden 3.
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
Bitiş Çizgisi
Anthony Platt
66 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-25, Maness Winter 2010 Cal Poly, Team 13-25, Maness Winter 2010 üyesi
CPSU-MANESS-W10S13G25
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 1,788
