Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
Use either end of the spudger to carefully pry off the camera lens mesh cover.
Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
Remove the cover by lifting it from right to left.
This should be similar to the action of the opening of a book.
