Ana içeriğe geç
  1. Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device. Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
    • Using a T5 Torx screwdriver, unscrew the two 5mm screws located at the bottom of the device.
  2. Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • Peel back the adhesive label below the camera on the rear to reveal a hidden screw, circled in the picture to the left.
    • If you peel the entire label off, two holes underneath will be exposed to future damage. Try to preserve the label to reapply later.
    • Alternate Procedure: Underneath the camera, feel for a depression and cut the sticker directly above the depression to reveal the hidden screw.
  3. Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
    • Use a #00 Philips screwdriver to remove the 2.5mm hidden screw.
  4. Use either end of the spudger to carefully pry off the camera lens mesh cover.
    • Use either end of the spudger to carefully pry off the camera lens mesh cover.
  5. Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
    • Using the #00 Phillips screwdriver, remove the two 9mm screws on the top corners of the device.
  6. Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off. Gently remove the case to avoid damaging it. Do not try to force the case open.
    • Spin the phone around so that the headphone jack is facing you. Run the flat end of the spudger around the entire edge of the device to gently pry the case off.
    • Gently remove the case to avoid damaging it. Do not try to force the case open.
    • The L shaped latches located on the bottom of the device make it hard to remove the case; you should run the spudger around the device's edges again if you are having problems.
  7. Remove the cover by lifting it from right to left. This should be similar to the action of the opening of a book.
    • Remove the cover by lifting it from right to left.
    • This should be similar to the action of the opening of a book.
    • The brown film connecting the motherboard to the screen may tear if this is not done carefully.
  8. Lift the control pad buttons off of the motherboard.
    • Lift the control pad buttons off of the motherboard.
  9. Wedge the flat end of the spudger underneath the battery and gently pry it out.
    • Wedge the flat end of the spudger underneath the battery and gently pry it out.
    • Be wary of the red and black wires on the battery, which may rip easily.
    • The battery may have adhesive holding it to the device.
    • The battery connector may rip if the battery is not removed carefully.
  10. Gently disconnect the white component connecting the battery to the motherboard.
    • Gently disconnect the white component connecting the battery to the motherboard.
    • The connector should be pulled upward.
  11. Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
    • Unscrew the single 3.5mm screw attaching the motherboard to the case with a #00 Phillips screwdriver.
  12. Disconnect the orange video connector leading from the lower case to the upper case with the pointed end of the spudger. The orange video connector is the cable that connects the motherboard to the screen.
    • Disconnect the orange video connector leading from the lower case to the upper case with the pointed end of the spudger.
    • The orange video connector is the cable that connects the motherboard to the screen.
  13. Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
    • Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side.
    • If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
  14. Using the spudger, pry the motherboard off of the device.
    • Using the spudger, pry the motherboard off of the device.
    • We recommend removing the motherboard off of the device from left to right.
  15. Feed the video connector from the camera through the square hole in the motherboard. After doing so, you may carefully lift the motherboard out of the back case.
    • Feed the video connector from the camera through the square hole in the motherboard.
    • After doing so, you may carefully lift the motherboard out of the back case.
Sonuç
Michelle Medina
63 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-49, Amido Spring 2012 Cal Poly, Team 6-49, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S6G49
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 743
