Ana içeriğe geç
Panasonic CF-31 Toughbook Keyboard Replacement
Neye ihtiyacın var
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: adım 1, 3 resimden 1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: adım 1, 3 resimden 2. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: adım 1, 3 resimden 3.
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 2, 2 resimden 1. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 3, 2 resimden 1. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 3, 2 resimden 2.
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 4, 2 resimden 1. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 4, 2 resimden 2.
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 5, 1 resimden 1.
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 6, 1 resimden 1.
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 7, 2 resimden 1. Panasonic CF-31 Toughbook  Keyboard  Replacement: adım 7, 2 resimden 2.
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
Sonuç
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 3,087
