Giriş
Step by step guide for replacing your damaged LCD Display.
Neye ihtiyacın var
Remove 4 (0.5mm) screws from the right side of the camera.
There are two screws at the top.
There are two screws at the bottom.
Remove 5 screws from the base of the camera.
There are two (0.2mm) screws next to the battery compartment.
There are three (0.5mm) screws around the tripod base mount.
Swap out your old LCD with the new LCD
You can purchase your LCD with Backlite or Without. It is much easier if your purchase the LCD with Backlite.
Panasonic Lumix DMC-TZ3 LCD Display Replacement Part VYK2C31
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Very well presented and helpful - thank you.
It sems important to use the correct screwdriver and my impression is that the screws are JIS rather than Philips.
So far I have been unable to locate a replacement screen with back light (I assume the back light is connected by the narrower ribbon cable).
I Like my Panasonic DMC-TZ3 , paid 300 way back in 2007 and has flawlessly perfect, till I Dropped it in the case …
IT still take pictures, store on Memory, etc all functions work , and can down load to computer ..
BUT the Back LCD I can barely see unless I put a LIGHT to it ….
SO I assume I screwed the Back Light, … can anybody help ?
Hi…. the backlite cable might have come loose or damaged. I would disassembly the unit and re-insert the backlite cable to see if that does the trick.. Otherwise you would have to invest in a new Display ASSY or backlite. A used backlite or Display assy is not that expensive and easy to replace..
